After porting all of the CPU functions, the original Sinclair code starts executing in its Arduino host. It stays in a loop waiting for a key to be pressed. This is not implemented yet.
If you look closely, the terminal window says this code is running on an Arduino Uno. For coding experiments, I tend to grab the closest available Enigma Machine Simulator that is laying around on my desk.
Time for a quick tweet:
