I prototyped Illuminatrix on my printer Cupcake155. Then I built the DeltaFlyer and recently got around to installing Illuminatrix. The original setup uses a full Arduino Diecimila. It's physically big and I decided to reduce some stuff on my second round with it.
Here it is in its second iteration:
Since I build my printers around ATX PSUs, I have 5V and 12V rails handy and that helps a lot for Illuminatrix. As you can see above, 5V from the PSU goes right to my board. I run the 12V line to my Vcc of my LED strip and that's it for power (plus GNDs, obviously).
I'm toying seriously with the idea of doing a PCB run to formalize this, I am very much not happy with wires hanging around, so I think there's a good chance I'll make this clean. In that event, I may order a bunch of extras and possibly make them available as kits. Please please drop me a line if that interests you, I wouldn't really be doing this to make money (I'm highly employed as it is).
