Revisions
- 1.0: First version from which i ordered boards from dirtypcbs. All wanted functions were integrated.
- 2.0: There were a nasty error in the board. Because i didn't have the Discovery Board at hand when i designed the board i assumed the pin headers are on top of the board. But i found out they are at the bottom. So i had to redesign the board to fix this bug.
- 2.1: The jumper selection of the "direction" signals was not correct. I used PE9 and PE10 but it was PE10 and PE11. Was only a minor fix to the board because PE10 is the standard signal.
- 2.2: After changing the pin headers in v2.0 the spacing between them were not correct. The distance between them had to be 2.54mm nearer to each other which is now fixed.
Rainer
