did final do a test in Hood Canal by Triton at 178m (584') and it all worked fine. I did upgrade the Lexan from 1/16" to 3/8" just incase. Videos are up on YouTube. Did have a problem with wiring a couple days ago I'm using solid core wires and with pulling this out and putting it in the housing had a wire break from fatigue.
