It wouldn't be Chopper without the little greebles that make him look like a pieced together droid.
The pipe detail is going to hide an emergency kill switch. I learned from K-9 that catching and shutting down a runaway robot is not easy when the off switch is inside. The cover is held closed via rare earth magnets so I can pull it off quickly and get to the off switch without pulling off his rear cover.
Kenneth Zaborny
