The motor supports for Chopper also support the drive wheels so they are constructed of aluminum with steel spacers. The motors and wheels used are from E-100 Razor scooters. They were purchased from Ebay.
In the image below you can see that I accidentally gave Chopper two right "feet". This was corrected later that day.
Kenneth Zaborny
