Chopper's body is a dual layer of styrene. The bottom layer is attached to the wooden frame with staples and silicon glue. The top layer is attached to the bottom layer with Weld On 3.
The back half of the body is a door to make getting to Chopper's batteries and electronics easier.
Kenneth Zaborny
