Final Thoughts
- This is pretty handy to have around!
- Connecting the activity light allows you to see network traffic.
- The Arduino Ethernet case is great for this application.
- I wish the Arduino Ethernet case was better made.
- I added an overkill DC voltage regulator - as I'm plugging this into $1000+ hardware right?
- Should run for a couple of days on a 9V.
- Someone should expand on this and add BlueTooth and a phone app!
- Arduino Ethernet is easy and cheap - Must make more things!
- Kris
Kristopher Marciniak
