Outlet drill motor speed controller
Using a triac for speed controller and putting it(the circuit) into a oulet box
This project consist of a mix of and outlet box and a drill speed controller the common one that use a Triac, the idea is to add the circuit to the outlet and select when you want to use the speed controller mode and when the straigth forward 120 ac voltage mode, the actual project was just designed for speed controller mode
It's has a LED to show when is powered or on, fuse holder, potentiometer for speed select.....
sorry if the description is to short but was a one day project and I dont even thinked of upload, but any Question just Ask
Alex Hassims wrote 03/06/2022 at 14:29 • point
This is amazing, I am also working on same project  you can see here https://charterspeedtest.info/cnet-speed-test/
