400x96x18BPP, parallel interface
Around Akihabara, this is known as the 300¥ Akizuki LCD display. If you search around for this display, you'll find many Japanese projects.
Datasheet(ish)
Here's a photo of my attempt to light up this display:
What follows are projects from other folks (entirely from Japan):
Anyhow, this is a pretty cool one. You can buy it from Akizuki if you happen to be in Akihabara.
Ian Hanschen
