Our small team has been working on this project since December of 2011. We now have a working model but still need technical help in making it more efficient and in working out a few remaining challenges.
We need help using and adapting Jay Dosher's python code so we can replace the sexy, easy-confusable LEDs with a program from the NASA that locates the Sun position according to time of day and latitude and longitude location to run on our Raspi. We're also uploading air temp data to the web through our Pi at this point as a test. Help!
Components
1×
1 1/2" Electrical tubing
for structure
1×
Sheet Reflective Mylar 4' x 8'
To cover collector
1×
Small D.C. motor
small D.C. motor to move collector(s)
1×
4' x 8' UV-resistant film
to cover and protect reflective mylar 4' x 8'
1×
4' x 8' x 1 mm sheet of PET
To provide foundation for reflective mylar and UV-resistant film
The following is a non-programmer's attempts to integrate python scripts from Jay Doser into our project using a Raspberry Pi, an H-bridge and an IMU. As you can see, it's in Spanish so if you wish help with the translation, please feel free to contact us.
We decided to stop trying to use a commercial electronic circuit with LEDs because they were always getting confused by the reflections from the collector so since we were going to use a Pi for sending the temperature data to the net anyway, we figured we might as well go all the way and try and use Jay's python program (although it's for two motors and ours only needs one) to oriente the collector.
Calentador
parabólica solar de agua
Rastreador
del Sol y el Raspberry Pi
8
de diciembre de 2015
Es
muy dificil empezar este proyecto pero se me ocurrió hacerlo por
partes.
1a
Parte Configurar el Raspberry Pi
Bueno,
hoy revisé las partes existentes para ver qué hacía falta. Cable
para Etherenet – presente. Cable para power – media presente.
Falta la parte que va a la pared. Tarjete SD – presente – 4 Gb.
¡Creo que tengo hasta 4 de las medidores de temperatura de tres
patas – Dallas 1820 Digital One-wire! We
need the 4.7K-10K
resistor. A la tienda...
Arg,
¿dónde está la lista de comandos para ssh y el Pi? No se
encuentran. A volver a empezar.
Jalál
encontró el último cable. Ya podemos conectar la pantalla/teclado
Motorola al Pi. A actualizar los programas con Synaptic – a
esperar – 250 Mb. para bajar. Como no hemos actualizado desde que
compramos el Pi posiblemente no vaya muy bien esta actualización y
habrá que simplemente reinstalar el OS. Ug. Mi bad. Tuve que
reiniciar el Pi y Synaptic se averió. Reiniar otra vez y NO usar
Synaptic sino Aptitude Package Manager (ver Others in Menu).
Luego
a establecer una conexión VPN o SSH para poder trabajar desde
LaGrandota directamente. Aha – SSH. Usando LaGrandota, abrir
Terminal, ssh pi@192.168.1.69 (o
lo que sea su IP – conseguir IP desde Router, Home Network, buscar
Raspberrypi. Luego, todavía en Term, “tightvncserver” para
empezar el server en el Pi. Luego, en LaGrandota, se puede usar
tightvncserver – creo. Nope. Usar XfVNC Viewer. Campos:
Computer name: 192.168.1.69; Screen: 1; Password: 48.... ¡Éxito!
¡Vemos la pantalla del Pi! “shutdown -h now” desde el Term as
root apaga el Pi.
Bueno,
ya tengo todo. Hice las conexiones con soldadura y la ayuda de
Yuguito. Coloqué el producto en el Raspi, arranqué el Raspi y
seguí las instrucciones
