I could do this all day.
A facehugger that jumps out of an egg when shot by a shotgun
One facehugger per shoot goes by fast! Happily, cardboard stands up to birdshot / target loads quite well.
A field-expedient way to get the most out of every Facehugger is to bring some duct tape. Taping a clay pigeon onto the back of Facehuggers actually works decently, and helps get the most out of each one.
Duct tape also helps if the Egg eventually comes away from the steel plate in the field.
Use laser cutter to cut out a Facehugger pattern and a paint stencil.
You can download the DXF file from the links section (left side of main project page.) Use only the outline to cut out Facehuggers. Use all the inside holes to make a paint stencil.
Each (blank) Facehugger will get painted via the stencil to make it look better.
Cut out a few Facehuggers and paint each one via the paint stencil.
Glue a clay pigeon to the back of each Facehugger.
