Big Button PI 3 extra
A project log for LED Christmas Pixels
using a raspberry pi to control lights over static network with Arduino Nano nodes
shane-bourgeoisshane bourgeois • 11/11/2016 at 21:22•3 Comments
i had and extra pi 3 and i have a 3d prtinter i thought it would be really cool to be able to start the show with a large wireless button to i used freecad and set off to work
jeremy.leroy wrote 11/26/2018 at 17:51 • point
Ok thanks, I known already option GPIO on the pi. but my goal is to activate pi (inside house), with ESP8266 with very small consumtion.I'll test to modify forkineyes code :)
shane bourgeois wrote 11/25/2018 at 14:46 • point
For for the big button I use the raspberry pi.
You very well could use an esp8266 and altar forkineyes code.
The raspberry pi is running falcon pi player.
Within the falcon system there are options for gpio.
And there you can run scripts and get ws2811 data
jeremy.leroy wrote 11/25/2018 at 10:02 • point
Hi Shane, so cool project, I follow it for the start, I used many parts of your system :)
Just a question, I think you used ESP8266 (maybe) on the big button.
Do you have schematic and code to use it??
thanks for your job
