** log in progress **
It took a lot of napkin sketches to come up with an enclosure that I liked for the wall-mounted LED strip + PCB assemblies as I didn't want to slap a rectangular box on the wall and call it good. I ended up designing a nifty 3-layer, laser cut acrylic assembly.
I'm pretty proud of this design for a few reasons:
- The transparent acrylic both allows me to show off my PCB design work and minimizes the visual footprint of the assembly during the day and other times when it is not in use.
- The top layers sandwich the LED strip to hold it in place which eliminates the need for any glue.
- The assembly looks reasonable mounted in either orientation (it's currently mounted 180 degrees off from the original vision seen above).
