I want to use my BlackIce-II board as a development and debug board for designs that can later on be moved to an FPGA-only design, where the STM32 provides a bunch of support features.
For example, the STM32 could be used to load a new bitstream, be a JTAG master to the FPGA (when you put a TAP in the FPGA), drive QSPI if you need the transfer speed, etc.
To make that work, it's really necessary to be able to use GDB during the STM32 development.
STLink Dongle
For that, you need an STLink v2 dongle that supports the Serial Wire Debug protocol. Turns out: these things are dirt cheap. You can get them on AliExpress for as low as $1.80 if you can stomach a 30 day shipping delay.
While looking for those, I also noticed an abundance of ridiculously cheap STM32F103 development boards. They go for $2.50 on AliExpress as well. (These boards are also advertised on eBay for the same price, but they *also* take more than a month to arrive.)
I didn't want to wait that long, so I bought the STLink + STM32F108 board for $12 or so on Amazon. $8 extra meant I had the thing at my doorstep 2 days later.
STM32F108 Blue Pill Development Board
Why the STM32F108? Because I already have a pile of micro controller boards. Why not have one more?
But also: there are plenty of tutorials on the web on how to get that board working with the STLink dongle and OpenOCD. So for just a few dollars more, I can replicate exactly the same configuration before I move on to great things.
I'm glad that I did.
I followed these instructions and, after swapping two wires, I had the thing going and was able to dump the contents of the STM32 flash contents. I'm currently not all that interested in getting C code to work on that one, but it should be pretty trivial, I think.
My drawer has a bunch of ATmega1280 boards from a previous life, an Adafruit Feather board with an ATmega and BLE, an LPC<something> board that I bought to see if it was still possible to an ARM7TDMI up and running (no issue with today's open source tools BTW), an Nvidia Jetson TK1 board, and some others that I'm forgetting.
But none of them are as cheap as this little thing. And it way faster than ATmega based products. If you want get into this kind of tinkering, and you want to do it cheap, these STM32F103C8T6 are absolutely the way to go.
Anyway...
Next step: getting it to work with STM32L433 that sits on the BlackIce-II board.
BlackIce-II with STM32L433
While the STM32F103 works find with OpenOCD 0.9.0 that comes with my Ubuntu 16.04 installation, this is not the case for the STM32L433. You need the stm32l4x.cfg configuration file for that, which is part of 0.10.0.
I started by connecting 4 pins between the dongle and the BlackIce board: GND, SWCLK, SWDIO, and 5V, and while that *did* result in some LEDs lighting up... a little bit, the FPGA didn't really come up. So I'm now NOT connecting the 5V and using USB instead to power the board. The STLink 5V is clearly not powerful enough to drive the BlackIce board.
I'm currently still at this dead-end:
adapter speed: 500 kHz adapter_nsrst_delay: 100 none separate Info : Unable to match requested speed 500 kHz, using 480 kHz Info : Unable to match requested speed 500 kHz, using 480 kHz Info : clock speed 480 kHz Info : STLINK v2 JTAG v17 API v2 SWIM v4 VID 0x0483 PID 0x3748 Info : using stlink api v2 Info : Target voltage: 3.234369 Error: init mode failed (unable to connect to the target) in procedure 'init' in procedure 'ocd_bouncer'
Connecting RST of the STLink to RESET_ of the BlackIce connector didn't work either.
So I'm stuck with that for now.
What I really want to do first is to have a multi-function interface into the FPGA with multiple virtual channels: STDIO, debugger for a RISC-V CPU, waveforms etc. If I can't get this to work, I might restore to just JTAG for a while and not use the on-board STM32L. Or I might even use the STM32F103 as driver as a temporary replacement.
