The USB isolator is not working for the bitscope noise.. so instead I focused on existing data and cleaned those..
Improvement was done compared to the previous image taken, as you can see below: we're quite on par with the medical image.
Still need to have a "clean" scan conversion using a 4Tap approach instead of a Nearest neighbour, anyone for a python challenge?
kelu124
