Exciting as it has been, the murgen-dev-kit project (GitHub repo) will be stabilized in the coming week. There's still some doc to fine tune, but, apart from that, the objectives are all reached:
- Getting a medical-grade image? Check
- Publishing the electronics sources? Check
- Developing the software framework? Check
- Documenting everything? Check
- Having a OpenSourceHardware-'compliant' repository? Check
However, on my path to hack ultrasound, murgen will give birth to a set of modules: instead of being a shield, the electronics are going to be transformed into a set of (breadboard) plugable boards, or modules.
To reflect, this I'm starting a new Hackaday project, the echomods. Feel free to follow this new adventure!
kelu124
