As I'm trying to get a signal around 1MHz, I'm also trying to get a proper acquisition.. the Feather WICED, sporting a STM32F205, should do the trick. I've been using two interleaved ADCs, and this is not so bad.. it gives the following results for the acquisition (and streaming over wifi):
for an original signal which looks like
