Mountig holes
A project log for SERVOcontrol
controller board for up to 18 Servos controlled by i2c or UART
alexAlex • 01/24/2016 at 15:04•0 Comments
I did add mounting holes at the sides. The holes are located on little break off tabs. If not needed the can be removed easily. The hole diameter is 3.2mm so M3 screws can be used.
The dimensions in the image are all mm
