YOU NEED:
- Luminol
- Sodium carbonate
- Hydrogen peroxide, 11.9%
- Potassium ferricyanide
- Agar
- Distilled water
- 3-D casting mold of different fishes (Amazon etc.)
- Lab glassware (Erlenmeyer flask, graduated cylinder, evaporating dish, beaker etc.)
- Bunsen burner, lab hot plate etc.
- Paper towels
- Tweezers
EXPERIMENTAL PROCEDURE:
- Pour 100 ml distilled water in an Erlenmeyer flask
- Dissolve 3 g sodium carbonate and 0.2 g luminol
- Heat the solution until it boils
- Add 1.3 g Agar
- Stir solution until Agar is dissolved
- Let the solution cool down to approx. 80 °C
- Pour the solution into the casting mold
- Let the solution cool down for at least 30 minutes
- Now you can remove the casted fishes from the mold
- Let them dry a little bit on paper towel
Fig. 1
Fig. 2
- Pour 90 ml distilled water in another Erlenmeyer flask
- Add 10 ml hydrogen peroxide, 11.9%
- Dissolve 1 g potassium ferricyanide in it
- Use tweezers to place one of the fishes gently in a vitreous evaporating dish
- Pour the water/hydrogen peroxide/potassium ferricyanide into the evaporating dish until the fish is completely covered
- Darken the room completely
- You should see a green-blueish glowing fish
M. Bindhammer
Anteneh Gashaw
Em
Josh
