Bed installed
A project log for DIY Pick and Place
Cartesian PNP machine using Rails/Carriages for high speed and accurate part placement. Affordable open source pick and place is on the way.
anthonywebbanthony.webb • 01/25/2016 at 06:03•0 Comments
Got the final bed installed. size is about 22 inches square. It is 3/4 inch mdf with a layer of 12 gauge (~1/8 in) galvanized steel laminated to it. It is probably a bit overkill but gives us a nice heavy base to stick magnetic holders and boards to.
