As of January 2016 all chips are tested on the bread board. I can communicate over RS232 at 19200 baud. The display is working but I have not yet tested how quickly I can render. I am just starting to experiment with writing in C using cc65. To date, all code has been writing in assembly using ca65.
Next steps:
- Figure out sound. Options are to experiment with somehow using 65C22 to generate PWM signal, or perhaps buy a vintage sounder generator chip online.
- Potentially go with 2 VIA's
- Finalize schematic so I can layout PCB
