All along I knew I wanted to figure out sound for Dodo because a game system just wouldn't be right without it. I have been going back and forth with lots of different approaches in my mind. Dedicated sound generation chips that mixed both digital and analog circuitry were the norm in the 80s. Perhaps the most famous chip of all was the Commodore 64's SID. Unfortunately, these style of chips are all out of production and I really wanted a design that avoids using old chips that are hard to find. I omitted a sound chip from the PCB so that pretty much left me with a single option, the 6522 VIA.
There are several methods for generating sound on the VIA using the shift register. I could either try for sampled audio or generate square waves at varying frequencies directly. For sampled audio the best I could get would be a 4khz sampling rate with 3-bit resolution, which is really only usable for barely intelligable voice. I opted for option 2 where I use the shift register to generate a square wave.
The Commodore PET lacked a sound chip so anyone wishing for audio did the exact same thing I have done, which is how I learned about the approach. It is documented in the PET programming manual.
For a square wave, either 15, 51, or 85 needs to be loaded into the shift register. The binary values are 0001111, 00110011, and 01010101. You can see from their bit patterns how they each result in a square wave. In VIA SR mode 4, the shift register is free-running and is based on the T2 clock, which is exactly what I want to get the sound going. Thankfully, the PET engineers did all the math to figure out exactly what values need to be loaded into the T2 clock to generate specific notes. This is straight from the PET manual:
octave=15 octave=51 octave=85 Note Oct.0 Oct.1 ! Oct.1 Oct.2 ! Oct.2 Oct.3 Freq ------------+-------------+-------------- B 251 125 ! 251 125 ! 251 125 C 238 118 ! 238 118 ! 238 118 C# 224 110 ! 224 110 ! 224 110 D 210 104 ! 210 104 ! 210 104 D# 199 99 ! 199 99 ! 199 99 E 188 93 ! 188 93 ! 188 93 F 177 88 ! 177 88 ! 177 88 F# 168 83 ! 168 83 ! 168 83 G 158 78 ! 158 78 ! 158 78 G# 149 74 ! 149 74 ! 149 74 A 140 69 ! 140 69 ! 140 69 A# 133 65 ! 133 65 ! 133 65
For amplifying a square wave not much is needed. I found an old NPN transistor (type bc170c) which I wired up to a 1w 8ohm speaker.
For the initial test I implemented some code that played the intro to Fur Elise!
... lda ACR and #%01111111 ora #%01000000 ora #%00010000 ; For sound (T2 free running) sta ACR lda #%11000000 sta IER ; Music lda #15 ; Low octave sta SR ldx #0 @next_note: lda music,x beq @done sta T2CL inx lda #250 jsr _delay_ms jmp @next_note @done: lda #0 sta T2CL rts music: .byte 93, 99, 93, 99, 93, 125, 104, 118, 140, 0
This Shift Register based sound generation will work well for my system because the CPU usage should be relatively low. Because the output is free-running, it will keep generating the same sound until instructed to do something different. I don't have to oscillate a pin directly myself to generate the square waves.
I can just have my interrupt that is already firing do a little extra work to orchestrate which sound to play next, should work well!
