For fun I hacked together a Christmas demo for Dodo. I found an animated GIF of a retro graphics style Santa which I then manually converted to monochrome. I use the program Pixen for laying out sprites. From there I took the 7 frames and dumped them as byte arrays and wrote a quick little program to cycle through the frames. The resulting sprite size was 42x48 so there were room to show 3 of them. The finishing touch was to get Jingle Bells playing in the background. Unfortunately 256 bytes are not enough to hold the complete song. I will go back and update the firmware to support longer music.
See it in the playground here: https://play.dodolabs.io/?code=f281ce54
Here is the original GIF: http://pug-of-war.tumblr.com/post/68955867425/its-pixel-tinsel-time-ho-ho-ho
