New Bottom 'Plate'
A project log for XYZ Repeatable Platform
Cruising Along
cyplesmacyplesma • 03/30/2016 at 00:31•0 Comments
Got a new piece of wood for the bottom plate installed, surprisingly the rougher 3/4" plywood was more expensive than the sanded 3/4" plywood. Also got on of the x axis rails in place. Bought a few different kinds of metal flat brackets to try and bend in 90 degree angles to mount the tool chassis to. Didn't see any 90 degree agrees that I thought would work. The bigger I needed the thicker they were which is what I don't want.
