After the humidity sensor, next to fail was a solar panel, which under the influence of elements started showing signs of wear. A close inspection shows cracks on the plastic cover protective film.
No wonder, it completely lost its ability to convert sunlight into electricity.
At the same time, the rechargeable battery seems to survive OK, but since I already have it on my desk it will be replaced as well.
