After the humidity sensor, next to fail was a solar panel, which under the influence of elements started showing signs of wear. A close inspection shows cracks on the plastic cover protective film.
![](https://cdn.hackaday.io/images/3403971667235552691.jpg)
No wonder, it completely lost its ability to convert sunlight into electricity.
![](https://cdn.hackaday.io/images/3081881667235720416.jpg)
At the same time, the rechargeable battery seems to survive OK, but since I already have it on my desk it will be replaced as well.
