void ADCH0_init(void){
_ADSIDL = 0;
//FORM<1:0>: Data Output Format bits
_FORM0 = 0;
_FORM1 = 0;
//SSRC<2:0>: Conversion Trigger Source Select bits
_SSRC0 = 1;
_SSRC1 = 1;
_SSRC2 = 1;
_ASAM = 1;
AD1CON2bits.VCFG = 0b000; // VR+ = AVDD, VR- = AVSS
_CSCNA = 0; // 0 = Do not scan inputs.
_BUFM = 0;
AD1CON2bits.SMPI = 0;
_ALTS = 0;
_ADRC = 0b0; // 0 = Clock derived from system clock
AD1CON3bits.SAMC = 0b00001;
AD1CON3bits.ADCS = 0b00000000;
AD1PCFGLbits.PCFG0 = 0; // Set AN0 as analog channel.
_CH0SA = 0b00000;
_AD1IE = 0;
_SAMP = 1; //Start sampling
It looks like I get less then 500 ksps, need to go through the code and figure out why.
Roman
