Preface
OLED requires 14V and VMU Zero generates it using Boost Converter. Conversion efficiency and output voltage ripple are evaluated.
Test Setup
Procedure
- Slide the Switch S1 to OFF position to disconnect the battery
- Attach the USB cable
- Display single color or white image on the OLED
- Measure I_in / V_in at R17 and I_out / V_out at 14V output
- [Test Case #1] Repeat 4 with varying the display image
- [Test Case #2] Slide S1 to ON and remover USB then Repeat 3-5
Results
OLED Power vs White Input Level
Efficiency #1 - VBUS vs 14V Output
Efficiency #2 - VBAT vs 14V Output
