Hackaday.io Hackaday.io
Sign up Log in
Vaulty
Secure SD to micro-SD Converter
antti-lukatsAntti Lukats
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1k views
0 comments
7 followers
  • Description
  • Details
  • Files 0
  • Components 6
    • View all
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
1k
0
7
5
Team (1)
  • antti-lukatsAntti Lukats
Join this project's team
hardware
ongoing project
This project was created on 02/01/2016 and last updated 11 years ago.
Description
SD Card sized, uses FPGA as middle-man between SD card pins and real microSD card. Experimental support to use 1.8V signalling and UHS-I mode.
Components
  • 1 × XC7A35T Xilinx Artix FPGA
  • 1 × S25FS256SAGBHI200 SPI Flash Memory, 32MByte
  • 1 × SiT8008 MEMS oscillator
  • 1 × LXDC2HL10A Power Management ICs / Power Supply Modules
  • 1 × LXDC2HL18A Power Management ICs / Power Supply Modules
View all 6 components
Project Logs
Collapse
  • PCBs ordered!
    Antti Lukats • 02/01/2016 at 17:40 • 0 comments
    And done.. order sent, PCBs to arrive next week. PCB thickness 0.35 mm!
View project log
Log In/Sign up to comment
Sign up with Github
OR
UD is open standard that uses SD Card form factor but is not bound to SD card specification.
Project Owner Contributor
UD Universal Digital Card
Affordable and attractive PCB business cards
PCB Business Card for Everybody
dimaDima
A card reader that uses black and white squares to identify a card.
Barcode Binary Card Reader
pete-prodoehlPete Prodoehl
just simple wav player from micro SD card
LEGO wav sound brick
bobriciusbobricius
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Vaulty", please tell us the reason.
Send message
Remove Member
