Hackaday.io Hackaday.io
Sign up Log in
Modular Teensy MIDI Controller
A modular take to a midi controller, using the Teensy LC.
max-litruv-boonzaayerMax Litruv Boonzaayer
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.7k views
1 comments
15 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 1
View Gallery
1.7k
1
15
11
Team (1)
  • max-litruv-boonzaayerMax Litruv Boonzaayer
Join this project's team
  • Blog
hardware
ongoing project
midi teensy
This project was created on 03/18/2018 and last updated 8 years ago.
Description
Going through several revisions of how I want it to function.
Currently designing modules to connect to a 10x10cm board. using board interconnects + multiplexing the outputs. (have 2 to spare on a Teensy LC!)
Project Logs
Collapse
  • Modules Being Created
    Max Litruv Boonzaayer • 04/17/2018 at 17:42 • 0 comments
    Rotary Encoder made!
    annnnd Slider Pot.
  • PCB Updates
    Max Litruv Boonzaayer • 04/17/2018 at 14:36 • 0 comments
    Going through a couple redesigns and commissions later, I've decided to make a modular device, multiplexing rotary encoders, buttons and whatever else, made with a configurator (wip) to generate the setup for the teensy to read (might just use serial + the eeprom instead of reprogramming..)
    https://litruv.com/knobber/ if you want to have a bit of a gander what I've got going.
    Commission for/u/sluggybear
    Front of the new board
    (Just noticed that screw hole being off - fixed already~)
    More to come soon enough.
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
Richard Hogben wrote 03/19/2018 at 18:47 • point
Cool screen print on the board
In this project, I decided to use the Seeed Studio XIAO nRF52840 board. Because a lot of the features I need are built into this board
Project Owner Contributor
Wireless Controller with XIAO nRF52840 Sense
cifertechCiferTech
Official Hackaday Prize Entry
A networked 1-wire controller
TeensyNet
jimmayhughjimmayhugh
An easy to build, simple to use stomp box for musicians using computerized effects for their electric/electronic instruments.
MIDI Stomp Box
thenetimptheNetImp
A Breakout Board for a Teensy LC and screw terminals.
Teensy BOB
pete-prodoehlPete Prodoehl
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Modular Teensy MIDI Controller", please tell us the reason.
Send message
Remove Member
