My coworker handles all things telecom at work and had a little drawer full of old 2GB microSD cards. While not big enough for the final version, 2GB is enough for the full software stack plus a couple albums to start with on the RPi Model B. In fact, it's the ideal size for testing since writing and backing up images happens a lot faster.
This is the first time I've worked with my Raspberry Pi B in a while and, oh man, did I forget how long it takes to install things versus the 2. This Model B is an early one, too so I'm working with just 256 MB RAM. The good new is it looks like mpd/icecast2 doesn't peg the CPU as hard as I feared. It shows just ~60% utilization on the Model B vs 40% on the 2. In the shot of top running below, you can see that even when I spam messages, a simple Node chat program barely shows up as a blip.
So that's encouraging. Oh, speaking of Node, make sure you don't try to follow the standard Debian install instructions on Joyent's github. That will work for the Pi 2, I believe, but not the A, B, or Zero, as they use the older processor. The basic steps I took were:
- Start with a fresh copy of Raspbian Jessie Lite
- apt-get update && apt-get upgrade
- apt-get install screen
- install and configure mpd and icecast2 per this handy blog post
- upload some music using psftp.exe
- Follow the steps from this thread on the official RPi forums to install a compatible version of Node
- wget http://node-arm.herokuapp.com/node_0.10.36_armhf.deb
- sudo dpkg -i node_0.10.36_armhf.deb
- sudo apt-get install build-essential python-dev python-rpi.gpio (I skipped this for time and space reasons; I don't believe I'll need b-e)
- Then I followed this tutorial to get a simple chat running with socket.io
From what I've seen it's relatively simple to have Node interact with the command line. I'm hoping I can whip up a program that occasionally polls mpc to get the current song and position, then starts a chat vote for the next song, artist, or genre. We'll see.
mark gunderson
