First POM print success
A project log for High-voltage assisted 3d printing
Attempting to use high voltage for better adhesion to print bed
deepsoicDeepSOIC • 03/13/2016 at 19:54•0 Comments
Finally, I've found the print surface I can print POM onto =)))))
This is an old LCD panel from a laptop. I ripped off the polarizer film (acetone helps doing it). The layer of glue that remained after peeling off the film is the surface I printed on.
And yes, I am holding the panel by the POM printout I just printed! It's well and truly stuck!!
Unfortunately for the project, high voltage has nothing to do about this success.
Data:
print bed T = 130 deg.C (temperature of the surface - setpoint was 150 deg.C)
extruder T = 250C (1st layer) / 220 deg.C (the rest)
