I based the current wrist on this camera quick release. As long as your tool has a part that matches http://www.thingiverse.com/download:42988 then my robot should be able to pick up and use your tool.
The PCB that is coming has a 12v power line and an RX/TX pair (with ESD protection). The 12v line can be turned on and off from software. That way you can communicate with and power the tool.
Now go to it!
Dan Royer
