https://www.instagram.com/p/BOim_CBjiaU
The biggest problems with the last arm design all stemmed from poor sensor construction.
- the wires were exposed to users where they could catch, fall off, etc.
- the sensor and magnet have to be held in perfect alignment or the arm loses sensation and goes nuts.
To fix that I'm working on a single sensor unit that I can test independently and use as needed in my next arm.
Dan Royer
