Hackaday.io Hackaday.io
Sign up Log in
Bicycle/moped wheel illumination.
Bicycle/moped wheel illumination. For the @home hacker.
emericaEmerica
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.9k views
0 comments
36 followers
  • Description
  • Details
  • Files 0
  • Components 4
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
1.9k
0
36
7
Team (1)
  • emericaEmerica
Join this project's team
ongoing project
nori norilights
This project was created on 04/28/2014 and last updated 11 years ago.
Description
Staying visible at night is important and this seemed like a very effective way to do so, while using very little energy.
So I set out to try a few things as buying a kit just seemed a little too easy and the price seems to really outweigh the components.
I wanted to try and keep the illumination as legal as possible, by using a red in the rear and a white in the front.
Details
Components
  • 16 × UV LEDS Quanity depends on the ammount you want to use and voltage etc. I'm using 4 per pod
  • 1 × Polymorph a small bag should do,
  • 1 × Phosphorescent paint or tape tape preffered, last longer and brighter, generally easier to apply.
  • 1 × Power source Depends on your led setup
Log In/Sign up to comment
Sign up with Github
OR
Uses MDF and some clever machining to store parts drawer thingies
Project Owner Contributor
Ultra simple storage system
itman496ITman496
I'm nearsighted and my VR headset doesn't have a provision to correct for it. Wearing glasses inside a VR headset was an awful experience!
Hacking VR: Prescription lenses & adapters.
cprossucprossu
An affordable and easy to make instrument to train and test fruit flies
Y-maze to study cognitive abilities in insects
wrijuWriju
If Otter falls and hits the top of his head, it can damage his brain, even be fatal; so we're trying to keep this area soft,padded,and safe.
Otter's Cap
brucejdiibrucejdii
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Bicycle/moped wheel illumination. ", please tell us the reason.
Send message
Remove Member
