More runtime numbers
A project log for LiFePO4wered/Pi
LiFePO4 battery / UPS / power manager for Raspberry Pi
patrick-van-oosterwijckPatrick Van Oosterwijck 03/25/2016 at 23:050 Comments
I finally got my runtime tests with the Pi Zero and Raspberry Pi 3 done, here are the runtime numbers in minutes for all Raspberry Pi's the LiFePO4wered/Pi can work with, tested with both the 3.2V and 5V LiFePO4wered/Pi versions, ordered from best to worst:
3.2V LiFePO4wered/Pi5V LiFePO4wered/Pi
Raspberry Pi Zero148118
Raspberry Pi Model A+145115
Raspberry Pi Model B+8065
Raspberry Pi 37664
Raspberry Pi 27262
All tests were conducted with a freshly charged cell, running the minimal Debian Jessie Lite image, connected to WiFi (using an Edimax USB dongle for all Pi's except the Pi 3, which used its on-board WiFi), an active SSH connection, one run of apt-get update, followed by regular voltage checks using the lifepo4wered-cli tool.
The Pi Zero runs the longest, for just about 2 and a half hours. This is only slightly longer than the Model A+, which makes a very good showing. I will have to experiment with some underclocking and other tricks just to see how long I can make it last, best case.
More surprising is that the Pi 3 seems to be a little more efficient than the Pi 2, which is unexpected considering its higher speed. It probably benefits from the on-board WiFi being more energy efficient than the USB dongle. I can't wait to see what we get when the RPi 3 Model A is released! :)
Rich text editor
