I finally got my runtime tests with the Pi Zero and Raspberry Pi 3 done, here are the runtime numbers in minutes for all Raspberry Pi's the LiFePO4wered/Pi can work with, tested with both the 3.2V and 5V LiFePO4wered/Pi versions, ordered from best to worst:
| 3.2V LiFePO4wered/Pi | 5V LiFePO4wered/Pi | |
| Raspberry Pi Zero | 148 | 118 |
| Raspberry Pi Model A+ | 145 | 115 |
| Raspberry Pi Model B+ | 80 | 65 |
| Raspberry Pi 3 | 76 | 64 |
| Raspberry Pi 2 | 72 | 62 |
All tests were conducted with a freshly charged cell, running the minimal Debian Jessie Lite image, connected to WiFi (using an Edimax USB dongle for all Pi's except the Pi 3, which used its on-board WiFi), an active SSH connection, one run of apt-get update, followed by regular voltage checks using the lifepo4wered-cli tool.
The Pi Zero runs the longest, for just about 2 and a half hours. This is only slightly longer than the Model A+, which makes a very good showing. I will have to experiment with some underclocking and other tricks just to see how long I can make it last, best case.
More surprising is that the Pi 3 seems to be a little more efficient than the Pi 2, which is unexpected considering its higher speed. It probably benefits from the on-board WiFi being more energy efficient than the USB dongle. I can't wait to see what we get when the RPi 3 Model A is released! :)
Patrick Van Oosterwijck
