breadboard prototyping of the powerboost + battery + soft-power-button circuitry
off (powerboost enable pulled low)
on touch of the push-button -> power on!
the three wires running to the top and out the image will be connected to the raspberry pi, and give it +5V, Gnd and a control/sense wire to the soft-power circuit - that way it will be able so detect further button pushes shutdown properly and cut the power by pulling the control-wire low
further description of the soft-power circuit is available here:
