of battery + powerboost + softpower-circuit
the breakoutboard is a cheapish chinese import, with a slightly different wiring for the backlight - the important part: the display is the same as in adafruits 2.2" pitft hat (and their 2.2" spi display breakout).
hence it is easy to get it up and running following these instructions:
