and 3d-components!
this revision fixes these errors:
- missing trace connecting powerboost:bat-low to the pi-zero
- wrong transistor pinout Q3 - turned out to be not needed and removed anyway
- clearance for protuding hdmi-connector tabs
- mounting holes undersized
- rerouted usb-traces (equal length, less vias and traces crossing)
- corrected usb-solder pad position
- wrong pinout on BJT transistor for backlight
diff of the copper layers:
JohSchneider
