Pretty cool update. I found some much better design USB Micro board connections.
They are only one piece instead of two, and they knock about 5mm off the distance of the board!
I'm going to update the design to include these.
A project log for PiAngle Zero - Not just another Pi Zero USB Hub
A plug-n-play 4 port USB hub for the Pi Zero - No soldering required! Also provides a power source for the Pi
