Some more pictures of the SPINet module prototype. Fischer SIL 1 G 20 / 10045917 really seem to be somewhat cheaper than the MillMax equivalents.
![](https://cdn.hackaday.io/images/9272501595684850951.jpg)
The contacts should have been a lot shorter, allowing a shielding can to be fitted to the top, and soldered on the bottom side around the exposed strips.
The test board also includes PoE taps, which will be investigated later.
![](https://cdn.hackaday.io/images/4580061595684903444.jpg)
