Some more pictures of the SPINet module prototype. Fischer SIL 1 G 20 / 10045917 really seem to be somewhat cheaper than the MillMax equivalents.
The contacts should have been a lot shorter, allowing a shielding can to be fitted to the top, and soldered on the bottom side around the exposed strips.
The test board also includes PoE taps, which will be investigated later.
helge
