JavaFX Based StarWars Clock on SPI Display.
Based on Rapbian Wheezy without any DesktopManager, uninstalled LightDM, Java8FX Engine writes JavaFX direct to Framebuffer.
Good instructions, but many tricky http://www.oracle.com/webfolder/technetwork/tutorials/obe/java/RaspberryPiFX/raspberryfx.html
EDIT /boot/config.txt like:
# uncomment to force a specific HDMI mode (this will force VGA)
hdmi_group=2
hdmi_mode=87
hdmi_cvt=320 240 60 1 0 0 0
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
dtparam=spi=on
Install fbcp to copy Main Framebuffer to LCD-Framebuffer.
sudo apt-get install cmake git
git clone https://www.github.com/tasanakorn/rpi-fbcp
cd rpi-fbcp/
mkdir build
cd build
cmake ..
make
install fbcp /usr/local/bin/fbcp
Create start.sh as Code example.
#!/bin/sh
#On Staging kernel not needed
#sudo modprobe fbtft dma
#Example for hy28B
sudo modprobe fbtft_device name=hy28b fbtft_device.speed=3000000 rotate=90 fbtft_device.fps=20
sleep 10
fbcp&
JAVAFX_DEBUG=1 java -Dcom.sun.javafx.experimental.embedded.3d=true -Dprism.glDepthSize=16 -jar /home/pi/StarWars.jar
