After repairing the screwy nand on the CHIP I decided to start on making it work as a PiFold/Anyfesto device. I reworked the scale on the Anyfesto Tower Case to fit the CHIP, a nice sized battery, a usb hub and some extras. The antenna will be for the FM transmitter, wether it winds up being an oscillating gpio or one of the Adafruit FM boards.
Now on to learn the base setup of the preinstalled Linux and see if things will just slide into place or brick the CHIP.
