HACKAMERICADOSUL
SECRET OF THE FASTEST MAN REVEALED WORLD
REVEALED BY MAN SCIENCE HACKAMERICADOSUL JP
Brasil josepedrofederal@yahoo.com.br
HACKAMERICADOSUL and exchange of available technology, South America - Brazil - a friendly and inclusive place for people who like to do things, sharing of knowledge and perhaps gain Millions of euros dollars.
The project is innovative uses technology already available, but do not use reducer and the electric motor revoluncionario this place imagined drawing.
flying orca
The helicopter traditional designs use a main rotor to generate lift and displacement, and a tail rotor for counteracting the torque applied to the fuselage. Another design known as the coaxial rotors, helicopter uses a pair of rotors mounted one above the other to give support and displacement.
To counteract the torque, the rotors rotate in opposite directions, creating equal and opposite torques which cancel and eliminate the need for a tail rotor. The yaw control is achieved by increasing the collective pitch of rotor collective pitch and decreasing the other. coaxial rotors also reduces the effect of lift asymmetry because as they rotate in opposite directions, the two sides of the rotor disc have a retreating blade and a moving blade. My project iclinaçao the lower upper thane helices are fixed (constant) the direction control is unique rear engine.
Another advantage of the coaxial rotor design is a greater burden for the same power output. As a tail rotor consumes some available energy produced by the engine, with the coaxial rotor design the extra energy is available to lift more load. Furthermore, eliminating the tail rotor reduces the noise, allows a more compact design, and increases safety on the ground.
The main disadvantage of coaxial rotor design is increased mechanical complexity of the rotor system. Two oscillating rotor heads and their control rods for both rotor systems have to be built on the same mast, and which in itself is more complex because of the need to rotate the two rotors in opposite directions.
However, this is partly offset by the elimination of the complexity of the tail rotor system. Despite the increasing complexity of the rotor system give rise to an increased risk of a catastrophic failure, helicopters with this type of design has a good track record of reliability.
Aula 3nano.pdf
Adobe Portable Document Format - 1.84 MB - 04/08/2016 at 21:34
Preview
nasa1.pdf
utilizei a base de calculo do rotor e demais componentes .
Adobe Portable Document Format - 1.79 MB - 02/24/2016 at 22:49
Preview
Giovanetti_duke_0066D_13193.pdf
revision of the calculations reviewing with the new design and type of engine (electronic electric)
Adobe Portable Document Format - 9.77 MB - 02/24/2016 at 14:55
Preview
analisex2.pdf
revision and motor design analysis to combustion. low control the height and horizontal speed
Adobe Portable Document Format - 1.09 MB - 02/24/2016 at 14:28
Preview
Trindade_Rafael_Henrique (1).pdf
Adobe Portable Document Format - 1.34 MB - 02/22/2016 at 22:01
Preview
View all 9 files
  • 1 × SIMULATOR FOR HELICOPTER FLIGHT
  • 1 × HP I7 COMPUTER
  • 1 × PROJECT AN EXPERIMENT HELICOPTER ALL DETAILS BUILDING, calculations CARGO CENTER
  • 1 × CALCULATION OF OLD WEIGHT (255 KG) AND NEW WEIGHT WITH SYSTEM CONTROL AND ELECTRIC MOTOR AND BATTERIES) WEIGHT (184 kG)
View all 8 hackerspace logs
Share this hackerspace
Rich text editor
Jose Pedro R. A. Ribeiro wrote 02/22/2016 at 18:24 point
Investidores  e profissionais são bem-vindos para se juntar a nós no projeto coaxial Helicopters elétrico,  para nos ajudar a alcançar nossos objetivos de produção em grande escala. Existem algumas regras rígidas que devem ser observadas quando recebemos ofertas de potenciais investidores, por favor leia as informações  cuidadosamente para decidir se o investimento  ou fazer(  contribuições  doaçoes ) para projeto inovador
1. Procure aconselhamento profissional independente.
Investimento   considerados de alto risco. Faça consulta    independente e procure antes de tomar uma decisão de investimento.
2. Plano de Negócios.
Uma cópia do Plano de Negócios do projeto   sera revisto e estará disponível mediante investimento ,contribuição .
3. objetivos
a. avançar o projeto  para a fase de pré-produção.
b. Reestruturação do grupo ,com mais técnicos
c. Continuar  o projeto compatível com os fundos disponíveis.
d. Promover o desenvolvimento do sistema de voo .
e. Promover o desenvolvimento de motores elétricos  de potencia de desenho inovador
O objetivo a curto prazo do grupo  é levantar  R$20000000,00 vinte milhões de reais
4. Orçamento
Apenas um número limitado de parcelas de investimento estarão disponíveis esse ano. A opção de investimento  R$400000,00  , já doações contribuições são de  livre valor .
Are you part of a hackerspace?
Create a page for your hackerspace and your members
