Raspberry pi zero
A project log for TimeArc
Led clock with a Raspberry Pi web radio
arminArmin • 04/10/2016 at 12:41•0 Comments
YEAH, finally found a RPi zero online. So I can continue the design.
I have been working with Kicad for the last couple of weeks. Not sure if I completely like it, but it seems to do the job. (I might be biased with 6+ years of eagle experience).
The schematic is finished and I am starting on the board file. the TOP layer will be on the inside of the enclosure. Most of the components go there. They can not be through hole because it will mess up the outside of the enclosure. On the BOTTOM layer there will be 12 ws8212 leds as a wake up light. There also needs to be an audio jack connector and a power connector (panel mount).
