As a first challenge I'm targeting http://www.instructables.com/id/Custom-Wooden-Train-Track-X-crossing/.
It would be nice If you can do something like:
var part = new iPath().line(3,0).line(4,4).fillet(4).line(4,0)....
part.reflect({x:1,y:1}).reflect({x:1}).reflect({y:1})
the fillet will put an arc with given radius between two straight lines:Unfortunately I have not been able to implement reflect and fillet reliable in iPath. As an alternative for now I use an array with line points, these will all be rendered in visible line, or arc segments. This array can passed as arguments to the functions reflectPath and arcPath.
