Find below the Bar Stool, easy in flatpack and convenient popped up. You are free to modify all parameters in the model, including the thickness of your plywood sheet. So you can make this template fit on any piece of plywood. The photo is a bar stool created from wasted concrete plywood collected out of the bins on a buildingspot in Amsterdam. Use this link to view the 2D model of the barstool.
jeroen
